Redmi Note 11 series
Krabs.
Alamak!! I bought from Shopee for $239, 4gb ram only!!!!!!!!!!!
shopeemall u can first tell the seller via chat you don't want the item anymore , cancel order
the seller of course will try to not let it happen , say the item processed by warehouse cannot be reversed or stopped at shenzhen or hongkong
tell the seller you will reject order at doorstep , at this point they don't give a direct yes or no ..... for my case the seller agreed my method is alright
i used the tracking to estimate around which day the local delivery , use clothespeg to kiap a4 paper with marker pen written the tracking number and i reject the order ..... deliveryman saw it and didn't knock my door .. item went back shopee local warehouse in sealed form and i got refund automatically
this case is preorder , 19th then ship ... got high chance you can cancel now yourself and get very fast approval to close order by seller
Krabs.
courts listed the pro and pro5g at 379 and 429 respectively .... currently no stock so cannot order
means they only bring in the 8/128 version for pro5g , if 18% coupon = 351.78
too high for me , nope :s13:
kinderbuenojhj
New release from Realme , which this same angmoh say ish a "killer" midranger wor (even openly snide XM with their latest RN 11 Series) .. :ROFLMAO:
TS, what chiur opinion on this fone ? Specs-wise quite swee le eg. OIS main cam (albeit 50MP nia), MTK D'SITY 920 5G, UD Fingerscan etc .. the cam design also notch bad , openly copy ifong 13 lol ..
but moi guess its notch gonna be cheap upon launch here , moi aga aga the 8/128 will cost at least $429-479 .. correct moi if wrong ..
:o
Hailgod
:o
this is pretty much the same camera design as all the recent realme, vivo, oppos.
i think this phone cost almost the same as a52s
tckrto
I just got me Redmi note 11 set from Hong Kong. First impression lighter than my Redmi note 8 pro. Camera seems better. Setup from google account backup went smoothly. And also manage to get company intune up and running. Speed wise cannot compete against flagship. Just nice fit into low end photo for normal usage nia.
kinderbuenojhj
Buy samsung a52 beter
Just done some comparing between the R9 Pro+ and A52s ..
indeed , if their pricing ish almost the same (eg. 8/128 vs 8/128) imo its better to go for A52s as it cums with slightly better screen refresh rate, cam (front and rear) and sd card slot albeit the charging is "slower" ..
kinderbuenojhj
Why chiu all like to buy HK set ?
cheaper than local set ?
:oops:
Sofa_King
Got NFC?
kinderbuenojhj
pigpigoink
Tot its stated the NFC thingy ish region-dependent , meaning some place will hv some dun ?
iirc local set consperm will hv huan , eg. if HK or other region sets might notch hv .. cos local set hv been verified by local distro approved by XM .. correct moi if wrong ..
mine has the ein sticker, means local product right?
Read HWZ Forum Rules!
waterballoon
:o
not "50MP nia". it's IMX766 that's also on OPPO FIND X3 PRO, GT NEO2 PRO, GT MASTER EXPLORER and other OPPO phones. it's a damn good camera sensor...
