iPhone 13 Series
jianrong
I just got iPhone 13 now restoring backup. I realise my signal bar is only 2 to 3 bar. And 5G don’t appear more than 4G.
jianrong
East side. One bar to two bar. When I turn on airplane and off it it go to 3 or 4 bars but soon drop 2 bar again. On average is 2 bar.
Habrosus
Hmm... Central, M1 full bar in 13PM, ST full bar in 12PM. Both set at 4G.
Could be location? How's your old phone's signal before this?
Snoweagle
Got so bad? I'm also at east side and here around 3 bars on average, sometimes full.
tamago_
Deluxe Member
Mine is consistently 2-3 bars, but no significant impact on coverage, data speeds or call quality.
crossbird
Anybody purchased iPhones through Shopee's Apple Flagship Store before? Wondering if anybody had any negative experiences to share e.g. regarding quality of items received.
sansanjikikut
Hi if my iPhone limited warranty expires on 28 feb. Can I still apply for and schedule for repair appointment after this date? Example today I make advance appointment for 2 March, which exceed my warranty date. Any cost incurred ? Assuming it’s an issue that is covered by warranty
ragnarok95
Senior Moderator
Senior Moderator
It will not be covered under warranty. The phone need to be serviced within the warranty period, not after. Making a appointment before your warranty end doesn’t justify it should be under warranty when service after your warranty date. Apple will still service for you, but it will not be covered under warranty and you might need to pay.
sansanjikikut
Good info thanks. Apple support gave template reply 😂
sansanjikikut
For iPhone screen repair at apple stores, do we need to provide our phone password to them or must die die factory reset phones before pass them to service? Including remove casing and screen protector
maple_mak
Regardless of what kind of repair service, they will ask you to factory reset
Just remember always backup for safety first
szeli
not 100% true on e factory reset part. I’ve had repairs done before. they just ask to disable Find My. of course u better backup before going just in case.
Whizdom
i just changed my telco from Circle Life to giga . While waiting for the line to be fully ported in , giga gave me a temporary number.
Now everything done.
And i keep receiving this pop up message.
