POCO X4 series
ZrE0_Cha0s
POCO X4 NFC, POCO F4 GT receive EEC certification, launch seems to be around the corner​
Tipster Mukul Sharma has spotted the POCO F4 GT and POCO X4 NFC on the Eurasian EEC certification site. Unfortunately, this is one of those certification sites that don’t reveal any specifications of the certified device. So, we don’t have any new information to share about the POCO X4 NFC and POCO F4 GT specifications. That said, the EEC certification suggests the phones could launch globally soon. You can expect to see them in Q1 2022. There is no major POCO phone launch expected in December.
From what we know so far, the POCO X4 NFC will succeed the POCO X3 NFC but the phone’s specifications are unknown at the moment. To recall, the POCO X3 NFC was launched globally with a 6.67-inch FHD+ 120Hz display, Snapdragon 732G chipset, 6GB RAM, and up to 128GB internal storage. The phone touts a 64MP quad-camera system and a 5,160mAh battery with 33W fast charging support.
We recently revealed that the POCO X4 will launch in India in Q1 2022. The POCO X4 Pro is expected to launch in India as well but there is no definitive timeline for the phone.
sauce: https://www.91mobiles.com/hub/poco-x4-nfc-f4-gt-eec-certification/
ThinkMe
luei74
Poco x3 GT = Redmi Note 10 Pro😡😡😡😡
Poco x4 = Redmi Note 11 Pro:mad::mad::mad::mad:
waterballoon
ai yo so X4 Pro is basically Redmi Note 11 Pro 5G. hahaha... not sure if SG will even bring in then. no point. both software exactly the same, everything is the same... what is Xiaomi/Redmi/Poco thinking/doing!??!!
subisisniki
Price out.
Early bird
128gb - 379
256gb - 429
Terrible phone, terrible price.
Lim reviews gave an honest answer. Its laggy compared to x3
ZrE0_Cha0s
Poco X4 GT
Normally, it is the F-series that is the pride and joy of the Poco line. However, the Poco X4 GT arrives with the exciting Dimensity 8100 – a mid-range chipset born in TSMC’s 5nm fabs with four Cortex-A78 cores and a new Mali-G610 MC6 GPU. This chip has posted some impressive results and usually outscores the Snapdragon 870 (and it can hold its own against the 888 as well).
so what do think about this model? rebrand from which xiaomi phone? :LOL:
sauce: https://www.gsmarena.com/poco_x4_gt...oco_f4_brings_an_sd870_instead-news-54780.php
Jurong640
For those using Poco X3 series, is there a proximity sensor during calls? I think some entry-level poco does not have that. When you are making a call, the screen does not dim
