ThinkMe
- Jun 4, 2011
same same but different but still samehttps://www.xda-developers.com/real...hyjBl3gMFsbOmQkJ7FQLPQpMhEQPRQdInjhXZ1nGiQdf4
91mobiles further claims that the Realme GT 2 Pro will pack a 6.8-inch WQHD+ flat OLED display with a 120Hz peak refresh rate, Qualcomm’s upcoming flagship chip, 12GB RAM, and 256GB FS 3.1 storage. Over on the front, the device will reportedly pack a 32MP selfie shooter. The device will likely run Realme UI 3.0 based on Android 12 out of the box, and recent leaks suggest that it might feature 125W fast charging support. While the renders show the device in two color options, Realme might launch an additional Racing Yellow variant like the Realme GT.
Realme isn't high end. low to mid range.From the comments, it looks like Realme only provides 1 Android OS update and up to 2 years of security patches. I expect 2 Android OS updates and 3 years of security patches minimally for a high-end phone.
If it's sold by sg realme store, then it will be global edition.will we get the global edition here or stuck with CN imports?
https://shopee.sg/realmeofficialacchttps://www.lazada.sg/shop/realme/?path=index.htm
Unless the games you play require flagship soc, Snapdragon 778 will be more than enough.sadly..nope....no flagship model here.
i need 512GB. Only local/global (non-CN) Android phone w/512GB is Samsung and Asus.Unless the games you play require flagship soc, Snapdragon 778 will be more than enough.
