oh does anyone know where to send poco f3 for repair? i think mine still under warranty - suddenly cannot charge..
change the charger or cable and try. maybe it is not the phone itself.oh does anyone know where to send poco f3 for repair? i think mine still under warranty - suddenly cannot charge..
oh sent to funan for repair - but gonna take a while before i know if it can be claimed via warranty. yah diff chargers a nd cable but still cannot charge. ha heng i still have my pixel 4a as back up.change the charger or cable and try. maybe it is not the phone itself.
i dont understand why need to use different charger just use the one they gave shld be ok mahoh sent to funan for repair - but gonna take a while before i know if it can be claimed via warranty. yah diff chargers a nd cable but still cannot charge. ha heng i still have my pixel 4a as back up.
if charger toast ur phone no warranty covered liao
try charge to 100 and use all the way to 1% then recharge again to recalibrate batteryJust got my new F3 on Friday n encounter battery drain. Noticed when screen off n on back it's suddenly drop 3-5%. Anyone encountered that?
Read HWZ Forum Rules!
Ok thanks. Will try it before return back to Poco.try charge to 100 and use all the way to 1% then recharge again to recalibrate battery
turn off memory extension. should fix your random rebootHi anyone having problem with your Poco F3 where the TraceTogether doesn't work? as in I can't tap and check in. I've opened up the app, bluetooth is on as well but just can never tap on the Check-in device... always have to use the QR code method which is very annoying.
Also the latest firmware version seems to cause the device to random reboot phone
