Charlie_Zhan
- Nov 17, 2013
Took Apple 2 years to come out with this feature
they are smart to delay this feature for 2 years to milk the sales of apple watch.
Read HWZ Forum Rules!
So far no issue on DBS, UOB and Standard Chartered banking appAnyone citibank app facing issue ?
Seems to freeze and doesn't allow any input at all unless you swipe up and kill the app.
Can u try the same? Although this method is working for my friend Citibank app, maybe u can try it on OCBC?Same too for me for OCBC Pay Anyone. Crashed upon opening it. Deleted and install it again, same issue and crashed.
I did experienced POSB app crash twice upon launching. I deleted my old Face ID and setup as new and can use normally already.So far no issue on DBS, UOB and Standard Chartered banking app
No need already. I already untick that option this morning where it says unlock with Apple watch.Actually now with this unlock with mask on from phone directly, no need the Apple Watch unlock le.
Somemore it is slightly faster than apple watch unlockNo need already. I already untick that option this morning where it says unlock with Apple watch.
Just need to lift my phone a bit higher haha.I got a feeling your eyes not opening big. Try opening slightly bigger so that the camera know u are looking at the screen?
I added another scan by looking higher. Seemed to workKeep asking me to look down. User problem here.
I tried, my DBS app, SingPass, Dash, Favepay, and a few others, all works perfectlyI did experienced POSB app crash twice upon launching. I deleted my old Face ID and setup as new and can use normally already.
I updated the app and my iOS to 15.4 It does not work at all. I reported to your team already. I deleted and reinstalled also the same issue. I took a video recording and sent to your team.
Do a reset by volume up then volume down then power button hold till Apple logo come out, release. I did this every firmware upgrade and so far never had issues with warm battery.I’m facing warm battery issue while on standby
Will do. It’s a soft reset?Do a reset by volume up then volume down then power button hold till Apple logo come out, release. I did this every firmware upgrade and so far never had issues with warm battery.
Yes, will not erase anything.Will do. It’s a soft reset?
First time experience this, batt charging also slowed to a trickle
