[Software Update] iOS 15.4
Matrock5
Hi there,
We are sorry for the inconvenience caused.
We are getting our team to investigate this. In the meantime, please log in to the main OCBC mobile banking app to perform fund transfers or use the scan and pay feature for QR payments & ATM cash withdrawals.
^XF
Thanks for the update. I am doing a lot of paynow transaction and the pay anyone app is very useful and convenient for me as compared to the main app which i still have to chose which acct i am going to transfer from.
fitzerspaniel
For those travelling, you can notarise and download your vaxx cert onto Apple Wallet via SingPass now! Damn convenient now
tohchr
If I set up face id with mask, will it unlock if I later never wear mask?
It will still work because basically, u are doing 2 scans. 1st scan is normal, after the 1st scan, it will prompt u for another scan which u need to select with or without mask. For those who already had their 1st scan done before the upgrade to 15.4, it will only ask u for the 2nd scan with or without mask after upgrading to 15.4. But for the 2nd setup, you are NOT require to wear mask just fyi.
tuntun
does anyone face an issue with a screen so dim suddenly after upgraded to 15.4 and restart?
I tried to manually increase. it back to dim again after reboot. Anyone advise? Thanks
tohchr
No such issue. Do a soft reset by volume up then volume down then hold power button until Apple logo appeared then release.
tohchr
Only see my cert dat can be downloaded in pdf in health hub . How to add to wallet?
From Singpass App, can u see "document" folder on the main page? Click on it, then u see your vaccination cert. Click to go in, then click view QR code, then select "For offline verifier, select the last vaccination which I suppose is the booster shot, then below click "Add to Apple wallet and Health.
Halo green
Nothing inside the document folder
Anxious
You need to go notorise.gov.sg to add the cert to singpass.. then follow the steps to add to apple wallet.
Halo green
Thanks. Added vax cert to SingPass and can see QR code (online and offline versions) but no option to add to Apple wallet
tohchr
Did u update your SingPass app to latest version? Only latest version support adding to Apple wallet.
Tokieda
anyone has charging issues with usb-c to lightning cable? it won't charge now after 15.4 update. tried with 3 different cables.
usb-a lightning cable works fine though.
tohchr
No issue for both iPhone 13PM. Using original Apple USB C to Lightning.
