First time Ops manning & ICT
zicron
There are units that take in guys especially like yourself, i.e. never get call up in many years and think that you have been forgotten, and quite likely not finish the reservist obligation before 40; so not forgotten just in a list and your name is at the top. What's the actual wording in your SAF 100 that says you should report in? If just no. 4 should be a 1 day affair right, I guess should be ok to report in old no.4 I've seen people reporting in that. Ops manning means cannot go overseas and be contactable within the stated period if I'm not mistaken.
matey1982
that's correct.
desmond_yee1
usually such units are evergreen units
DriftKing
For Ops Manning, what will be the reporting attire? (missed the info from the call)
Will ready up a set of FBO packs in case kena called-up (Formation called me after I contacted NS Hotline), and for ICT mentioned ok to just wear old uniform in, will do 1 to 1 swap in camp.
Btw, seen DGsoldier came out with a nicer packed labled for the FBO items, are they actually allowed? Or still must get zip lock?
Chalkycliffs
Nobody really cares how it is packed, just have it packed correctly and easily identifiable (clear plastic, can see which item is what without opening).
DriftKing
That's good to hear. NSF time needs to be of the same zip lock and tape it up to a compact size.
