Oinkize
- May 22, 2009
Lucky you.....Mine is the green set, have been using 6 months . No peeling issue
My inner screen protector us lifting up already, especially at the middle part. Anyone changed to 3rd party ones? I've asked around and all shop seems to do rubbery film type only.
I saw there is a film type from whitestone, not the dome silk which had alot of cracking issues
https://www.whitestonedome.com/coll...ng-orginal-film-anti-bubble-hd-clear-pet-film
Get Samsung to change it for free
Any idea what's the turnaround time? Can't wait for 2 days while they take their own sweet time to paste a screen protector...
less than an hour
Read HWZ Forum Rules!
ok thank you! Will go to Samsung
Hahaha thanks. There doesn't seem to be many options, only 4:3 and 16:9Have you tried the built-in aspect ratio modifier?
Go to Advanced features -> Labs
There are many options there that you can tweak, per app.
Just updated. Thank you!new firmware one UI 4.1 update is out, FYI
Just updated mine. Thanks for notify.new firmware one UI 4.1 update is out, FYI
You can check on the GOSJust updated mine. Thanks for notify.
Immersive mode is back with multi windows. Hope nothing detrimental about this update.
Edit: battery life seems to have taken a hit with this update
No GOS optionYou can check on the GOS
You lucky lor. My black set hinge got paint peeling already...Been using since Nov.. hopefully no peeling happening to me....
