I saw one shopee store selling after today only voucher discount is $438youtube
No longer listed from their shopee lists, but 8/128 still available
If u r ok with the 8/128, believe 6.6 shd have further discount,can get ~330 or lowerI saw one shopee store selling after today only voucher discount is $438
legit. i see ppl washing their iphone with soap. then suddenly cannot turn on anymore he kpkb.
then go buy new one -1.5k$ lMAO
Firstly, it is water resistant, not water proof. Two different meaning. Secondly, electronics enemy is water, i won't risk to rinse my phone under water, or even exposed it under rain regardless how heavy the rain is![]()
Where is this option at? can't seem to find itFor those who updated their poco f3 to global 13.0.3 version are you able to turn off anti flicker mode? In version 12 I'm able to turn it off but after update it seems like can't turn it off
It's under display if you are on miui 12Where is this option at? can't seem to find it![]()
Does Poco F3 has nfc by default? Can it work? I heard there's issues. Is it still worth the buy compared to other poco variant or against Redmi Note 10 pro?
Thanks for any advice!
Download and configure using wireless@sg app?My father's POCO F3 is not able to connect to the Wireless@SG in public libraries. He can connect to home Wi-Fi though. Anyone encounters this and any fix, please?
The closest solution I can find is this:
https://c.mi.com/thread-1783685-1-0.html
As mentioned in the link you posted, manually connect to Wireless@sgx, not wireless@sg, and use SIM as the EAP Method, if his phone doesn't have a supported SIM card, tough luck, the app doesn't work for a few phones but you can try, or buy one of those cheap prepaid sim card, one $5 m1 card can easily last a year with expiry validation extension if you don't call/sms using it.My father's POCO F3 is not able to connect to the Wireless@SG in public libraries. He can connect to home Wi-Fi though. Anyone encounters this and any fix, please?
The only issue i know of is the tracetogether app which is a bluetooth issue, which a lot of people falsely attribute to NFC.Does Poco F3 has nfc by default? Can it work? I heard there's issues. Is it still worth the buy compared to other poco variant or against Redmi Note 10 pro?
The speaker is ear breaking loud, why you need strong vibration?I'm on Xiaomi.eu MIUI ROM 13.0.5. Switched from X3 NFC.
Is anyone experiencing weak vibration when there is incoming call? I left the phone beside me (~20cm away), and can't hear the phone vibration when there is incoming calls or msgs.
maybe can consider wearing a mi band? then u will be alerted via mi band when u have a notificationI'm on Xiaomi.eu MIUI ROM 13.0.5. Switched from X3 NFC.
wireless sg usually quite slow and unstable.My father's POCO F3 is not able to connect to the Wireless@SG in public libraries. He can connect to home Wi-Fi though. Anyone encounters this and any fix, please?
if your dad is 60 or above, maybe can consider tpg senior plan?
$5 per month for 20gb
https://www.tpgmobile.sg/seniors-sim-only-plan
Use miflash and flash it back lor. Most likely u need factory reset as is downgrading from android 12 to 11After upgraded to MIUI 13.0.3, are we able to revert back to MIUI 12.5.6 if wanted to?
Go anywhere with wireless sg (don’t need to do it at library) and help him set up. Lol why you ask old people to do it by themselves and librarian.He is on TPG senior plan already.
However, he loves going to the library to read and occasionally surfs Internet. Hence, he needs the Wireless@SG to minimise the 20 GB data.
I have given him the above steps and the librarian had resolved the connection. Hope it continues working.
Thanks for the help.
