Seems like only have 128gb version. Don't have the option to choose when adding to cart
its on the recommended optionIt's under display if you are on miui 12
like virtual reality?Seems like only have 128gb version. Don't have the option to choose when adding to cart
u can use the $30 off $280 to get $294 thomanaged to snatch it @ $299 for 6/128 as a spare phone. within my budget
fkkk hahaha nehmind.u can use the $30 off $280 to get $294 tho
$294 is shopeefkkk hahaha nehmind.
lazada never auto deduct eh?
weird my shoppe shows $500+ that’s why I went to Lazada$294 is shopee
lazada about $278~$291.40
shopee $329 only on blue/black. white $500+
Yes, a thin film enough to last u till u find a better 9H glass one.anyway just to check.
does it comes with pre-installed screen protector?
Till u dropped the phoneYes, a thin film enough to last u till u find a better 9H glass one.
Ooh under miui 12? Yes VR should be using the cardboard thingy that you purchase separately that you put your phone into it to view VR contents.its on the recommended option
but what does it mean display in VR?like virtual reality?
Get a case to protect the falling phone. The free one is a bit thin.Till u dropped the phone
Ibywind is a good brand got TG
