Toader
- Dec 4, 2006
4K SDR shot
4K HDR shot
Trying out the seamless zoom... with my hands full and crowds lol
Video quality is good!
4K SDR shot
4K HDR shot
All 4k video will make phone /camera heat up fast. Sony did 6 minutes the other phones auto stop at 5 minutes if I'm not wrong
Sounds like it imhoChecked my battery usage, screen usage is the most at 40+ %, while other apps are less than 10%. My screen brightness is probably around 40%. Is this normal?
Vs retail msrp yes. But vs shop price I think is still higher. I think shops is 1.7k on carousell?Bet the Xperia Pro I also heats up..., those who got XPro I any feedback... my X1iii heats up like an oven...
Btw, this is the T3 airport price in Sony airside, is it cheaper?![]()
Yes its cheaper. The current selling price is $1969 with the speaker.Bet the Xperia Pro I also heats up..., those who got XPro I any feedback... my X1iii heats up like an oven...
My screen is at around 21percent. What's your usage? You turn on creative mode and high refresh rate? I turn them both off hahaChecked my battery usage, screen usage is the most at 40+ %, while other apps are less than 10%. My screen brightness is probably around 40%. Is this normal?
Ah good catch haha, yes both are enabled for me. How's your battery life with those two settings off?My screen is at around 21percent. What's your usage? You turn on creative mode and high refresh rate? I turn them both off haha
Haha not bad ~ Its likely 120Hz that's draining most battery life. Also disable adaptive brightness. Only using it to test out sunlight legibility. I also disable digital wellbeing (last time it caused some glitch to the xperia 1III) as well as disable many notifications besides those useful ones.Ah good catch haha, yes both are enabled for me. How's your battery life with those two settings off?
Even for supposedly cooler but older chips like SD865 (which the 1 II and 5 II are using)?Yes its cheaper. The current selling price is $1969 with the speaker.
Xperia pro i also heat up. Watched reviews they got say. Currently none of the smartphones solve the heating of 4k and above video recording
Yes it was the same on the Pro-I, the thermal limit was around 50c before app shutdown. For continous 4k recording, I only managed to keep the temp to 46c by sticking a cooling fan on the back of the phone. Seems like the thermal limit is lower on the IV, not very surprising considering it packs arguably a hotter SoC and has a thinner body compared to Pro-I.Bet the Xperia Pro I also heats up..., those who got XPro I any feedback... my X1iii heats up like an oven...
Used 1II last time. You can see my post in the 1II thread ~☺Even for supposedly cooler but older chips like SD865 (which the 1 II and 5 II are using)?
“No plastic IN packaging”. Clever marketing since plastic is ON packaging lol![]()
Joining in the party!
Isn't the tape plastic? Haha
But mine inside got dust... fingerprint..wah, got seals. mine just shrink wrapped with gladys(plastic?) wrap, with no seal
Try video and selfie too![]()
Xperia 1iii vs Xperia 1iv... the difference is pretty stark...![]()
Side note, any1 using 5G on the phone yet? Can't seem to get it working on my st line. Works on my pixel 6 pro and iPhone..
