Sony Xperia IV
GeSteSoh
All 4k video will make phone /camera heat up fast. Sony did 6 minutes the other phones auto stop at 5 minutes if I'm not wrong
Bet the Xperia Pro I also heats up..., those who got XPro I any feedback... my X1iii heats up like an oven... 🥵
Btw, this is the T3 airport price in Sony airside, is it cheaper? :unsure:
mortpenguin
Checked my battery usage, screen usage is the most at 40+ %, while other apps are less than 10%. My screen brightness is probably around 40%. Is this normal?
xtramadness
Sounds like it imho
Vs retail msrp yes. But vs shop price I think is still higher. I think shops is 1.7k on carousell?
Toader
Yes its cheaper. The current selling price is $1969 with the speaker.
Xperia pro i also heat up. Watched reviews they got say. Currently none of the smartphones solve the heating of 4k and above video recording
Toader
My screen is at around 21percent. What's your usage? You turn on creative mode and high refresh rate? I turn them both off haha
mortpenguin
Ah good catch haha, yes both are enabled for me. How's your battery life with those two settings off?
Toader
Haha not bad ~ Its likely 120Hz that's draining most battery life. Also disable adaptive brightness. Only using it to test out sunlight legibility. I also disable digital wellbeing (last time it caused some glitch to the xperia 1III) as well as disable many notifications besides those useful ones.
darkarn
Even for supposedly cooler but older chips like SD865 (which the 1 II and 5 II are using)?
berber
Yes it was the same on the Pro-I, the thermal limit was around 50c before app shutdown. For continous 4k recording, I only managed to keep the temp to 46c by sticking a cooling fan on the back of the phone. Seems like the thermal limit is lower on the IV, not very surprising considering it packs arguably a hotter SoC and has a thinner body compared to Pro-I.
On a side note, anyone using the original kick stand case? Is it any good?
ALacs
wah, got seals. mine just shrink wrapped with gladys(plastic?) wrap, with no seal
xtramadness
Side note, any1 using 5G on the phone yet? Can't seem to get it working on my st line. Works on my pixel 6 pro and iPhone..
