which probiotics brand is good?
Theres a $1 offer on this one:
https://sg.iherb.com/pr/california-...iotics-5-billion-cfu-10-veggie-capsules/64008
I only need a 10 day course, so perfect for me.
There are different types of probiotics for different purposes. Check out the "13.Probiotics tab" in this excel file GET319.xls for notes/ideas of what needs the the different probiotics serve. Click on the stain's name to get further details.
Then check out the reviews for each of the brands that interest you. It would give you a good idea how effective the probiotics are.
Still not sure what or which to buy? Then check out this excel file GET319.xls for the price-value comparison tables for best value buy if you need to get.
Of course this is the best value but you can only buy 1:
anyway i realised, sometimes they may have concurrent promos e.g. 20% for 6.6 and say 30% for cardio supplements.
If you check out your cardio supplements under the 6.6 promo code, you only get 20% off.
You need to check out the cardio supplements separately with the 30% off code for 30% off!
nope you didnt miss it, it was just an e.g.!You are right.
The lower discount applies, so you have to separate your order.
When was the 30% discount for cardio supplements.
I missed that
Can anyone recommend me an affordable and reliable 1,000mg vitamin C with time base release properties?
Thanks in advance.
Thanks again for your recommendation.https://sg.iherb.com/pr/natural-factors-vitamin-c-time-release-1-000-mg-180-tablets/2556is the best buy for Timed release because not only is it the cheapest, each tab comes with 50mg of Citrus Bioflavonoids Extract and 25mg of Hesperidin
Otherwise this is the best value for 1000mg but you can only buy 1:
https://sg.iherb.com/pr/california-gold-nutrition-gold-c-1-000-mg-60-veggie-capsules/61864
or the best buy for Buffered is this
https://sg.iherb.com/pr/california-...n-c-capsules-750-mg-240-veggie-capsules/84570
Wa! I just saw it.26SUPP - 26% off supplements & herbs, ends 9/5 10am PT
Just ordered mine and saves $3026SUPP - 26% off supplements & herbs, ends 9/5 10am PT
