- Sep 16, 2018
Thank you for the info. If Singtel also like that then there's no reason for me to switch.
Yes, latency for game(jp, us servers) actually quite good with MyRepublic.
Yes that is right.
In order to have good latency to China servers, it seems to me China VPN (or using some other VPS as the intermediate) is needed.
I have subscription to AJS China VPN for contents comsumption (720p or 1080p) and it also helps to reduce latency. But usually I do not use it for WeChat call -- nowadays we just use Wechat Voice call more often and only use Wechat Video call occassionally (sometimes it is okay, sometimes it is not okay).
Good thing about Singtel is probably Taobao mobile app (not using Taobao website though), we never really have much issues with that -- quite some reports of issues by MyRepublic and Viewquest users, but I think they tend to use Taobao website (s.taobao.com can be a problem).
Code:
PS C:\Users\xiaof> ping s.taobao.com
Pinging v6-sh-sz-zb.wagbridge.alibaba.taobao.com.gds.alibabadns.com [59.82.9.88] with 32 bytes of data:
Reply from 59.82.9.88: bytes=32 time=174ms TTL=82
Reply from 59.82.9.88: bytes=32 time=175ms TTL=82
Reply from 59.82.9.88: bytes=32 time=273ms TTL=82
Reply from 59.82.9.88: bytes=32 time=182ms TTL=82
Ping statistics for 59.82.9.88:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 174ms, Maximum = 273ms, Average = 201ms
PS C:\Users\xiaof> ping www.taobao.com
Pinging www.taobao.com.danuoyi.tbcache.com [163.181.36.225] with 32 bytes of data:
Reply from 163.181.36.225: bytes=32 time=10ms TTL=54
Reply from 163.181.36.225: bytes=32 time=6ms TTL=54
Reply from 163.181.36.225: bytes=32 time=7ms TTL=54
Ping statistics for 163.181.36.225:
Minimum = 6ms, Maximum = 10ms, Average = 7ms
