barnabaskoh
- Oct 25, 2006
what is network reset?Do a Network Reset to see if it helps.
In that case. Give redONE a call for help.i just tried..also the same..
See if below helps:
APN: redone
MMS Proxy: 10.128.1.242
APN Protocol: IPv4/IPv6
Ensure WIFI is turned OFF when making above modifications; i.e. connected using mobile data.
Try using the settings above. Got it from RedONE helpdesk.I just sign up.i saw the 4g and signal but no internet.any idea why
Are you having issues in Singapore or Malaysia? If data is not working in Malaysia, probably data on roaming is off somewhere in phone settings?i just tried..also the same..
Was using the local data bundle for the past 2 weeks in Jiuhu but found the signal/network lacking in some places, e.g., in Kuala Selangor and my hotel room in Taiping. Totally no signal in the ulu part of Northern Malaysia, which is the same as my ONEXOX card so no compliants. Hardly full bar most of the time but data usable for driving and accommodating the kids playing games at the same time.
Not sure if due to my old phone (Pixel 3AXL) or the network coverage itself.
Roaming is like RM38/Day? Which is like not worth?u only need ONEXOX and in Singapore use the best network which is Singtel mvno.
Can you share a screenshot of your apn list from phone settings?mine is in singapore. cannot use since i sign up..the challenger staff say is their network down..than msg and whatsapp redone morning , they say fastest need 2 days to solve.. keep asking me do the same repetitive steps that i done so many times..
Has your porting completed? Nowadays most telco doesn't give temp numberI just sign up.i saw the 4g and signal but no internet.any idea why
Mine is new number.didnt port..I can't share pic here..Has your porting completed? Nowadays most telco doesn't give temp number
I didn't create any redONE APN but my data is working fine on starhub postpaid APNFor those using Andriod/xiaomi phones, may I know if you need to create a new redONE APN ?
When I look at my existing APN, I don't see any "redONE" APN.
I think you can talk to their CS. But most probably you will be charged $10 plan change feeMy mum signed up redone years back when it was giving 3GB, 100 mins local and 1000 mins MY talk time and 10 outgoing sms. I saw the new amazing8 plan now gives 5GB, 300 mins talktime and 300 sms. Like to switch over to this new amazing8 plan. Is the plan Amazing8c in the dropdown?
I switch from the old Amazing8 to the new Amazing8c thru their phone App, Select Value Add services and chose manage your Add-ons and look for the Amazing8c. Simple and straight forwardMy mum signed up redone years back when it was giving 3GB, 100 mins local and 1000 mins MY talk time and 10 outgoing sms. I saw the new amazing8 plan now gives 5GB, 300 mins talktime and 300 sms. Like to switch over to this new amazing8 plan. Is the plan Amazing8c in the dropdown?
