Asphodeli
Has anyone tried porting OUT of TPG prepaid to big 3 prepaid? Is it working?
Tyrian
Hey guys.
do I need to top up my SIMBA wallet to auto renew or?
another question. When I sign up only got $10 plan. How to upgrade?
lohsenglte
Hey guys.
If you signed using Credit/Debit Card, no need unless error.
If you used cash, yes. Min 1 week before renewal.
No way to upgrade without porting out and back in. There's just NO mechanism to do so.
JivBunny
Hey guys.
For me, I just put $50 every 3 months when I pass by one authorised tpg shop near my office.
it just auto deduct every month. I find it’s simpler that way then to give them my Cc details.
baby0nboard
Hi may i clarify, so faq say cannot upgrade or downgrade plan..
So I was wondering how does one purchase more roaming data in tpg? Or that is not an option?
baby0nboard
You can do online topup too.. No need to go to shop
sullycoin
When you finish the included roaming data package on your plan, it will deduct $4 from your wallet & give you another 1GB of Group A roaming data (assuming you are in Group A country, of course). Other groups will deduct the appropriate amount from your wallet.
You do need to take note that it doesn't seem to work if your wallet does not have enough balance to buy more roaming data, even if you have a linked credit card.
a4973
Hi so is the deduction of $4 for another 1 GB of Group A roaming data automatically processed without line user's consent? Eg tonight I am flying back and I just ran out of roaming data. I can still get by either using public WiFi or hot-spotting from a fellow traveller. How can I not have the "renewal" go through? Thanks.
sullycoin
Yeah, pretty sure it is automatically deducted.
You can prevent it from renewing the roaming by making sure you don't use more roaming data. Easiest way is to switch off data roaming on your device.
lohsenglte
It will be charged at blocks of 10MB, which means it's $0.04/10MB.
However, if you don't have any money in the Account Balance, there's no way to deduct, so you won't be able use data roaming at all.
lohsenglte
Account Balance topup has to be done manually, not auto deduct from your credit card.
a4973
Ok thanks, since the charge is in 10 MB blocks then don't have an issue with Auto renewal. Thanks for the update.
baby0nboard
Thank you.. So you need to have account balance for the auto deduction to work.. Thanks again as I can't find it in FAQ.
fake_oranges
When overseas, need to use the app to call out or receive calls?
or can just call like in sg?
VOLTE phone user
