GIGA SMS Message Centre Number
Missyrat
Hi, can anyone using giga help me by providing the giga SMS Message Centre number? Thanks
Missyrat
I am unable to receive OTP from banks for verification purposes. I called up my OPPO centre and they told me to input the giga SMS Message Centre number. Searched high and low on the net..... Even emailing and messaging giga. But no luck to find this freaking number. I am desperate as my credit card bills are due soon. Can anyone help???? Thanks so much.
sadboy
Usually you don't need to manually enter SMS number.
Did you just recently port over to GIGA? Like last then 3 days?
firesong
Deluxe Member
Just do a reset network settings, and your phone should populate the correct settings and flush out all wrong configurations. I've found that on some phones previously, when users manually edit the APN settings, it sometimes doesn't properly update even when they swap out SIM cards. Since all telco profiles are now with nearly all manufacturers, just reset and let the phone pull up the default profiles automatically.
chaozhouzi
Check your setting for block contact list. Recently my OPPO mysteriously stop receiving OTP from my regular bank. Turn out it was blocked as shown on block contact list. After removing from list, I am receiving OTP again.
