Android TV Box
speedbolt
hi all, wanted to get a tv box but has no idea which to get.
any recommendation? like ubox or evpad? thanks !
Philippng
ubox more costly. i have use ubox for 7 years still running like new.
What is important is you need to do maintenance every now and then.
Flush the local drive clean. then reboot the system. Not to worried about system file.
Flush and factory reset is a different thing. Do only factory reset if you are sure how to get it back
midlusionz
Gotten the Mecool box, its indeed good, what tools do you guys use for maintenance? Ram Cleaner?
Philippng
hi bros
there are too many cleaner tools. I am using a very old app called clear cache cleaner lite ( cannot find it from google playstore maybe the upgrade name is different)
This cleaner is good bec while you are using the app, it clear the memories automatically without affecting your usage but if you need to clear cache u still need to manually do it. pm me if you want a copy
midlusionz
Cool, so i can just let it be yeah? using TVB anywhere, netflix and disney+ very happy with my mecool purchase
kevinlaikf
Most Amlogic S905X4 overheat in a 24x7 operation.
Anyone had positive experience of a S905X4-based tvbox in a non-cooler-fans operating mode?
cochran
Anyone using this ifibre apk? or bought their ifibre cloud box?
How is the quality of the apk? 388 day for $120
Zetrio2006
Anyone knows which android box can actually play tv shows from Viu?
Someone told me the ott box apparently can but only works on tablet???
Trueblue82
i nv done it before but u cannot go dl the viu apk and then installing it manually to your android box?
Zetrio2006
Even if you install Viu, the Viu player also cannot play any video because Viu sets a lot of restrictions.
But I heard from some people some android box will work for Viu.
gregory_choo
if your box is running android TV OS, such as 'mibox s', the easiest way is to run viu on handphone and chromecast the video to the box.
alternatively, you can sideload a mod version of viu for tv.
if your box is based on handphone android or mobile android, just install viu for tablet, it might work.
razoreigns
Hi, can anyone advise if the mi TV stick 4k is better compared to mi box s? It seems like prices in Lazada are about the same.
