You connected by wifi is it? I use LAN cable direct to router no issue lawah hang 4 time liao the stream.....jialat sia
singtel TV number is on your monthyl billmy dad called singtel to enquire about this, the CSO told my dad to sign up online which i did so on Tuesday. I dont know how this crossover works? I tot recontracting online means it'll carry over and can watch liao but turn on TV channel 102, description says Fulham Vs Liverpool but it shows a static screen telling you how to find your singtel TV number.
wonder this on IPTV got such issue?“Video defects inherent from source” roflmao this Starfug…
It’s not about giving you a good experience. It’s about increasing their subscriber count**** starfug go bid for what **....
obviously no capability to handle this.... just let Singtel take forever....
Confirm u connected by wifi.
i obviously know that la. Recontract liao means need wait how long before can watch?singtel TV number is on your monthyl bill
Fake news, BTsports stream no such issues“Video defects inherent from source” roflmao this Starfug…
I got this issue earlier in the half also, I connect by LAN cable not wifiConfirm u connected by wifi.
Pls use LaN cable
user problem
Lan or wifi should not have any difference given the bitrate is like 5mb max?Confirm u connected by wifi.
Pls use LaN cable
user problem
Mine not even a single picture freeze on my tv box.I got this issue earlier in the half also, I connect by LAN cable not wifi
Mine totally no issue connected by lan cable.Lan or wifi should not have any difference given the bitrate is like 5mb max?
