i already got iPhone 12 pro. dun need another one.Haha how come you dislike iPhone?
Shouldn't. Think its either your cable is defective / power bank defective.Hi! all. just got my set. i tried to charge it with my existing 3rd party usb C cable and powerbank. but it doesn't seem to work. does Xperia 1iv require a specific model?
noted will try againShouldn't. Think its either your cable is effective / power bank defective.
OR,
try restart your phone after you setup so many settings updates and applications.
I have no 5g on myrepublic. VoLTE works.Does the 5g and VoLTE work? Currently on GOMO.
Both Starhub 5G and VoLTE worksDoes the 5g and VoLTE work? Currently on GOMO.
Currently using xperia 5 ii(export set) but green line appeared on screen so looking around for options.. The 5G, VoLTE dont work on my 5 II. Even on Singtel network before switching to MVNOs. Now we are at a stage of don't know if a certain phone's 5G or VoLTE will work or not.
Exactly, after spending so much on getting the phone u like, still have to depend on whether telcos like your phone or not.And I thought it is bad news that some countries with telcos that sell phones which are locked to their individual network. It is already 2022 with 5G networks still not fully developed and our telcos are no better that a 4G/5G capable phone cannot use 5G or VoLTE on local networks. What a shame.
1. 5G is still a big gimmick in 2022, no killer app I can think of that can use the theoratical speed difference over 4G. Also greater battery hog.Currently using xperia 5 ii(export set) but green line appeared on screen so looking around for options.. The 5G, VoLTE dont work on my 5 II. Even on Singtel network before switching to MVNOs. Now we are at a stage of don't know if a certain phone's 5G or VoLTE will work or not.
Misinterpreted opinion as fact, doubt that Sony will do such thingsWoah rumored USA will probably getting snapdragon 8 plus Gen 1 processor
https://sumahodigest.com/?p=11958
Yes I also doubt. Don't see Sony using any plus version processor.Misinterpreted opinion as fact, doubt that Sony will do such things
Yup. Same as me.i can confirm m1 has VOLTE but no 5G
Yes cheap Bluetooth remote. Then go menu set volume button as shutter. During this mode when you connect your Bluetooth you likely unable to bring up keyboard to type.Nice! Wanted to try last night but scared battery not enough. How did u trigger shutter? Bluetooth remote?
