- Jul 5, 2001
Fits in the pocket better than nexus 6I finally got to try the phone at Challenger.. honestly I think it's fine for me.. just that I'm not used to the shape/size. also how do you guys fit the phone in your pocket?
Bro you showing your age, you should say fits in the pocket better than Nokia Ngage.Fits in the pocket better than nexus 6
Or pagerBro you showing your age, you should say fits in the pocket better than Nokia Ngage.![]()
haha I used only Nexus 5.. so no frame of reference.Fits in the pocket better than nexus 6
It will fit naturally after you bought it.I finally got to try the phone at Challenger.. honestly I think it's fine for me.. just that I'm not used to the shape/size. also how do you guys fit the phone in your pocket?
N6 taller and widerhaha I used only Nexus 5.. so no frame of reference.
Woooo... U got collect this ancient phone...N6 taller and wider
Maybe next #teampixel event can showhandWoooo... U got collect this ancient phone...
U really should open pixel museum with @garychengjw korkor
I'm using rugged armor. More is less should be the same.. not really thick and good gripAnyone using spigen liquid air case? Is the case thick and good grip?
Reminds me of a liquid air case I use for iphone 7 long long ago. The case becomes loose after a while and the printing behind caused marks at the back of the phone.used before liquid air for other phones.. case is not very thick.. but offers decent protection.. grip is good.. only thing is I find that the sides abit loose..
So the $600 Amazon promo also include Fitbit?Friend received his set liao... 600 bucks for p6a + fitbit
Yup. But no more liao leSo the $600 Amazon promo also include Fitbit?![]()
Long time, no root liao tooEasy peasy... I do till dont want to do liao![]()
