I using
Maibenben 2500U
mini pc 25
LAN port and m.2 wifi DOA (I got post in that Maibenben Thread)
I bought it barebone @ SGD$300 from Aliexpress
Other than that no issues.
I running it 24/7
Now more than 1.5 year liao still okay
Maibenben is lower quality compared to
Minisforum/Beelink
If they didn't catch both forms of networking broken out of the box, I will straightaway return it and ask for refund. IMO doesn't bode well for QC if they can't catch two problems when it's brand new. Dunno what else they never check properly.
I can't tell for sure that Brand A is better than Brand B, unlike say a motherboard where you have reviewers like HardwareUnboxed comparing the actual quality of a cheap board, so I personally hesitate to recommend such brands.
1) Form Factor alot bigger than mini pc also alot more power consumption 15-25W Mobile CPU vs 65W Desktop CPU (I ran 24/7, 1 year save over $100 in power saving cost)
2) People usually don't upgrade CPU due to chipset and CPU limitation for upgrading
1) Power consumption will get more significant the more you use. If use 24/7, of course the power consumption difference will become large. Anything x 24 x 7 x 365 will become a large number.
Alternatively, if its used 8 hours a day the difference becomes just $33 a year. So that then has to be balanced against warranty lengths and part replacement costs. Is the full 3-5 years warranty on an entire PC's worth of parts worth $33 a year? I would say definitely yes.
2) That's why I said TS must consider if he needs a small PC or needs a really small PC. By upgradability I meant not just CPU, it's the entire DIY PC suite of upgrades. Whether multiple SSDs, 3 HDDs, 4 sticks of RAM, graphic card, CPU cooler, whatever you want to upgrade you also can do. Totally different from a mini PC experience.
Usually you can only salvage Casing + PSU if you DIY
Cos might not be worth it to buy replacement MOBO or CPU say 3 years down the road
If you already on 5700G, there is no further upgrade option available for CPU
At most buy a replacement MOBO if MOBO spoil
As with any standard form factor system, only the parts which break need to be replaced and there is always the option I stated below.
Even if the motherboard dies and you can't find another, sell your CPU and get some money back to put into a new CPU+MB with the newest socket.
