[new] Heya.sg
888888888888
IMHO.
I think today morning I don't have internet. Been 3 months, so far so good but will monitor. Thanks.
seeing few auto-disconnects, early last mth dont have. superbslo
to be fair, will check again when no rain.
small_being
Heya! Anyone knows the default SIM lock PIN?
Tried Singtel PIN 0000 once & didn't work. Left 2 attempts.
Appreciate & TIA!
firesong
Deluxe Member
Appreciate & TIA!
IIRC it's 1234.
In any case, you can always call the operator to obtain the PUK code to unlock the PIN if you lock yourself out. You will need the long SIM number printed on the SIM card though.
small_being
IIRC it's 1234.
Yes that it is - 1234!
PIN successfully changed. Thank a lot bro!
liulianice
Hi all, my only concern is that if we can make voice call like normal line, unlike tpg cannot make or receive call
keenklee
IMHO.
I disabled the VoLTE and it can make voice call.
Anyway, it is not known if VoLTE is a feature as previously, for a period, the feature disappeared.
liulianice
IMHO.
oic, was thinking if i should replace my giga main line.. think not to risk, just replace my tpg line and test it out. if ok then replace my main line. thanks for the info ya
sango65
PSA: After 3 mths of 100GB data each, the data cap of 200GB will kick in
Before top up just now: -
Main: $0.00 Exp:09-09-22.
heya Plan: 200.762GB Local Data,893 Local min,148 Local SMS, Exp:10-08-22.
After top up: -
Main: $0.00 Exp:08-10-22.
FREE Local Outgoing Calls Offer:57 min, Exp:06-09-22 15:15:10.
heya Plan: 199.981GB Local Data,1350 Local min,198 Local SMS, Exp:08-09-22.
So try to use up to 150GB of data left after 3 months before topping up the 4th mth
Kiwi8
Deluxe Member
After top up: -
It was already stated in their website and the TnC pdf file what.
addict951
High Honorary Member
Guys, just nao I went to sign heya. The shop Unkle collected $10 from me. Correct hor? This is the first month’s sub? :s12:
@Kiwi8, did you pay?
addict951
How ar? Which line did you switch to Heya?
I switched my Giga line to heya. 2 reasons why I did so: #1 Giga’s coverage is as trashy as M1/Myrepulsive. Last weekend’s Giga incident was the last straw; #2 Can top-up using Shopee. :s12:
Kiwi8
Deluxe Member
Yes, this $10 is for the first month's sub (in fact, this is not the full month, just 30 days, meaning 1 day will be eaten for those months with 31 days).
Kiwi8
Deluxe Member
What Giga incident did u encounter last weekend ah?
Kiwi8
Deluxe Member
addict951
I see....
From what I understand, is it their VoLTE not working? Cos some users mentioned that once they turned off VoLTE on their phones they could call out again.
In fact reading about this incident worries me too, cos I planning to port to Giga, haha. In the opposite direction as yours. :o
You pran to port from huat to Giga? The 4G is also problematic. You go to basement sometimes then you want come in edmw you will see white screen, ie. no internet, even though phone on top show 4G and full bars. Must toggle aeroplane then the internet coverage resumes. Many times riao. Pek ceks man. Even at NPC too. Wtf
