GRABPay MasterCard
Froggyman
Just to check, can we top up our wallet when oversea?
Confuse over the term for grabpay card user .
Thanks.
How to top up my GrabPay Wallet with credit/debit card​
You can top up your GrabPay Wallet instantly and directly with your debit/credit card. If your GrabPay Wallet balance is low, start topping up in 6 easy steps!
📝 Notes:
  • At this time, users cannot top up their GrabPay Wallet while overseas. You must be in the country where you registered your GrabPay Wallet for top ups to be successful. For example, if you have a Singapore GrabPay Wallet, you cannot top up your balance while you are in Indonesia. However this is not applicable for GrabPay card users.
  • For GrabPay card users, you can still top up your GrabPay wallet while you are overseas as long as you already have a card added on file.
Ark Law
Thanks.
📝 Notes:
As far as the wording goes, as long as your Grab Wallet already has a linked GPMC, you can use any saved card to top-up Grab Wallet.
I've topped-up using my AMEX TCB overseas and immediately moved the newly topped-up money from Grab to Revolut. All within 2 minutes.
plustwo
is there any reason to use grab points for anything other than to straight up offset qr scanning? grab allows the exact same conversion rate of 5000 points for $10 which is arguably better than redeeming for stored value vouchers.
twosix
Vouchers sometimes can be exchanged with discounted points.
marcho21
Its fine la.. Haven seen it since a long time le. The more discount, the higher the competition to be fast fingers.
Trazora
this has been the base rate for some time already. On top of this there was 20% pointsback just a few days ago.
vsvs24
Last time they had the 70% for $5 Grabfood voucher. That one very worth to redeem points.
Recently I redeem Domino personal pan pizza for 1650 points. That works out to be $3.30 which I find worth. Get voucher code and order at Domino website, not Grab.
BRYSG7
I'm waiting for this as well. So far this month still hasn't popped up
spikeling
Anyone got problem topping up grab wallet today? Can't top up today at all using all different cards...
