- Jul 5, 2001
hi have you managed to resolve this problem?Either way it's same for me. Which telco are you on? I'm on TPG and as far as i know, TPG hasn't enabled VoLTE for P6
yup had to do this in order to make callsUse their voice app ?
https://www.simba.sg/voiceapp
Google is the one to be blame for not supporting call over 4G. If apple camp can do it why not Google?Either way it's same for me. Which telco are you on? I'm on TPG and as far as i know, TPG hasn't enabled VoLTE for P6
is your set local? then bring back to get battery change ?I have 2 pixel 6 pro. I set became very hot and battery drain during normal use. Another set is normal.
Really CMI this Google. The more I use the more problem popping out. Seldom do I hear normal use will result in heat issue and battery drain. This is really a master piece.
It;s local set but it''s a software issue, changing anything will not help. IMS service kept running in the background sucking up all the battery.is your set local? then bring back to get battery change ?
Updated to 13?I have 2 pixel 6 pro. I set became very hot and battery drain during normal use. Another set is normal.
Most people just want to use the phone as it is.My Pixel 6 recently bought from Google Store also has the same IMS service battery issue despite doing a clean install...Am using Singtel GOMO. I ended up disabling IMS service and the battery life became very good.
Have yet to upgrade to Android 13 and enable IMS service to check if things would become normal
See @simply.90 earlier postAfter Android 13, Google pay no longer has vibration. Couldn't find any setting that causes this. Any solution?
Vibration and haptic is on as usualSee @simply.90 earlier post
Have to wait dev to update the app or wait for next patchesVibration and haptic is on as usual
