Starhub Giga
Byfrost
You seem to have a major issue with searching for existing threads and joining in existing discussions, some of which have answers to your questions. There is no need to create a new thread for every question you have. This is not EDMW.
There's an existing Giga discussion thread right on the first page where you posted this. You don't even need to search cos it's right there. Same for your many other threads that you just keep creating and dumping here rather than posting in the existing discussions and relevant subforums.
This is not EDMW.
it's easier to open mouth to be spoon fed than to do the work yourself.
crystalnox
Really horrible. 4 bar here at ridley, same no signal or need to wait a long lag that last more than 30 secs.. need to connect to different simcard and connect back to get a functioning signal that again last a few mins. Had enough of it..
Usually toggling airplane mode for a few seconds fixes it, no need swap simcard.
Fellowes
Sadly the $10 for 10GB is not available for existing customers to switch plan. Those that was using $10 for 6GB too bad for them.
kazuki666
Actually paying $10 for 10GB, why dont get SIMBA? Personally I have a Giga $18 as main line for personal, simba $10 as supplementary line for work. By right the data and call minutes will be enough by Giga $18 plan, but I prefer to cut work after office hours, so thats why got a second line.
thekh21
Hi had their upgraded to 10g ,but noticed my usage data been used up pretty fast in matter of days as compared to 6g before .
Anyone had this issue as me don't DL videos etc?
xonix
Check your phone apps data usage.
You should be to find the answer to your question there.
kazuki666
That shop seems to do for quite a few telco. Is those typical neighborhood beng small shop.
