Makes sense, thanks so much for your reply! Yeah I've been having that issue in general all electrician don't know how to install video doorbell.. Even though their website portfolio states otherwise..Eufy is under Anker. As far as I know, buying stuff from UK is $$$$! The two links appear to be the same, the battery version. I have pointed out earlier that this dual cam doorbell has a wired version. I don’t think the battery one comes with wired unlike Arlo or Google latest video doorbells. If you go for wired version, you will need a transformer/adapter.
Battery only version
Wired only version
I haven’t find the perfect video doorbell. So can’t recommend any electrician. Read that some electricians refused to do the job because of transformer/adapter. Don’t understand why.
If me, I will go with wired setup. Why? Once the electrician setup the wiring and if the video doorbell get bust, I just replace it another one with similar power specs. Replacing batteries is a hassle and I don’t want to draw neighbours’ attention.
Anyone else that has lobang/contacts who can help install the Eufy video doorbell dual please let me know, thanks in advance!!
