Sony Xperia IV
viperx
Using HK set, able to get VOLTE. As I'm on a 4G line, I never notice a switch to see 5G. Not sure if it will work ....
I'm on UK set(Xperia 5 II). No 5g, no VoLTE 😂. Tried Singtel, circles, gomo.
wolvie77
Anyone knows what the green notification light on the top right is when I am in camera mode? It comes on for a brief while and shows a video icon before the green light.
ranchy
Ah that's bad..
My friend local set Xperia 1 III has volte on Singtel.
He somehow able to get 5G connection even though he's using a 4g line.
ranchy
It's like an indication that the camera is being used . If you use other apps and activate camera , it will shows also.
Can pull down from notification bar and click on it to see it.
xtramadness
Here we go!
64.0.A.8.82
winner22000
No issue with the image
Thanks for the testing.
The shop already replaced me with the brand new set. Mine are HK 512gb set but the shop still willing to help me fight for the brand new set from supplier. Not sure if I can tell the shop name here but the location is far east plaza. The shop at level 2 and you can see it from outside
wolvie77
I bought mine from that shop too haha
Toader
Mobile square?
