Toader
- Dec 4, 2006
yes same. Don't see any pixel or box when display below 90 percent.Are you using the latest firmware? 64.0.A.8.25
And the brightness below 90%?
I'm on UK set(Xperia 5 II). No 5g, no VoLTEUsing HK set, able to get VOLTE. As I'm on a 4G line, I never notice a switch to see 5G. Not sure if it will work ....
Ah that's bad..I'm on UK set(Xperia 5 II). No 5g, no VoLTE. Tried Singtel, circles, gomo.
It's like an indication that the camera is being used . If you use other apps and activate camera , it will shows also.Anyone knows what the green notification light on the top right is when I am in camera mode? It comes on for a brief while and shows a video icon before the green light.
NSA vs SA.. dont get "con"fusedAh that's bad..
My friend local set Xperia 1 III has volte on Singtel.
He somehow able to get 5G connection even though he's using a 4g line.
Oh okay... nut at least see it... I never saw once once on ivNSA vs SA.. dont get "con"fused
thanksIt's like an indication that the camera is being used . If you use other apps and activate camera , it will shows also.
Can pull down from notification bar and click on it to see it.
What's this update about?![]()
Here we go!
64.0.A.8.82
Anyone of you has this issue? The black in dark area will looks pixelated or boxes when the brightness adjust below 90%.
Below is the original photo you can use for testing
Not sure yetWhat's this update about?
Tap the image button then click to insert image (link)How do you guys post photos here in the forum?
Thanks for the testing.![]()
No issue with the image
I bought mine from that shop too hahaThanks for the testing.
The shop already replaced me with the brand new set. Mine are HK 512gb set but the shop still willing to help me fight for the brand new set from supplier. Not sure if I can tell the shop name here but the location is far east plaza. The shop at level 2 and you can see it from outside
Mobile square?Thanks for the testing.
