- Jul 14, 2005
wah bro
you even have the phone that i alw dream of having
but my pocket says otherwise![]()
good phone. Way better built and feel in hand than z flip 4 tbhwah bro
good phone. Way better built and feel in hand than z flip 4 tbhStill using or sold already? How many phones you keep at a time sia...good phone. Way better built and feel in hand than z flip 4 tbh
Hahaha get bored then sell loStill using or sold already? How many phones you keep at a time sia...
u should consider rog phone 6Maybe wait for the Dimensity ver.Hahaha get bored then sell lou should consider rog phone 6
broFlip phone, don't expect thermals to be good. Normal use is ok
Hahaha, alamak. Thought Motorola razr. My bad... Carrying kid in hand.bro
finish the video =)
not about the temperature eitherHahaha, alamak. Thought Motorola razr. My bad... Carrying kid in hand.
That's why they give aerofan for cooling... Didn't expect to be so warm
look at his screen =)
My friend zf8, press power button, back glass crackyour fren is martial arts master? 内力 so good?My friend zf8, press power button, back glass crack
i also dont know why. So his zf8 used 2 to 3 months, byebye liao![]()
just got my Ace Pro , flashed to global rom.
-Singpass Working
-Singtel Volte Working
-Singtel 5G Working
-widevine L1
Passes safety net. Mcd can useCan the device pass safetynet test ?
Also can it use the mcdonalds app ?
Thanks for the reply. Is yours is the local set or the CN set but flashed to global rom ? I wanna buy the 512gb version cn set which will be flashed to global rom so kinda worried about safety net and Mcd.Passes safety net. Mcd can use
Dont need worry. Those flashed CN set flash global rom one, bootloader is locked, as long as it is locked, safetynet will pass. Don't worry so much about itThanks for the reply. Is yours is the local set or the CN set but flashed to global rom ? I wanna buy the 512gb version cn set which will be flashed to global rom so kinda worried about safety net and Mcd.
Thanks Bro. Now to wait for 9/9 vouchers before i buy. If anyone knows the best way to stack vouchers for a $985 purchase feel free to share k .Dont need worry. Those flashed CN set flash global rom one, bootloader is locked, as long as it is locked, safetynet will pass. Don't worry so much about it
My demo set is local set. But rest assured CN set flashed with global rom will work fine
