SEvsNK
- Mar 31, 2004
Ya now i feel like trying out the H2. The reviews seems consistant across the board.Noctua NT-H2 is good in the test.
Cooler Master Unveils Purple-Colored “CryoFuze Violet” Thermal Paste With Exceptional Thermal Performance
Seems like color paste will be the future![]()
at U$30 ya its too expensive, nevertheless I got the original non purple version on sales at S$9.90 during May-22.Quite expensive at USD30 a pop. Think I will stick to my cheap MX-4.
ya.. 30 usd price can buy the ssy 157 liaoat U$30 ya its too expensive, nevertheless I got the original non purple version on sales at S$9.90 during May-22.
Before i start reading the details from the link. Wccftech editor Hassan Mujtaba somehow had quietly answered the Qns many people who are going to ask. ''Is the CryoFuze Violet worth buying?''Cooler Master Unveils Purple-Colored “CryoFuze Violet” Thermal Paste With Exceptional Thermal Performance
Now you know why more and more companies are trying to come up with thermal compound. Gram for gram, high end thermal compound cost more than buying pure silver. I don't see the weight mentioned on this CM Thermal Compound, but the normal CM CryoFuze was just a 2g. If this is also 2 grams, then its USD 15 per gram. That's daylight robbery.Quite expensive at USD30 a pop. Think I will stick to my cheap MX-4.
If you have dealt with TFX, the paste is so dry that even 1 stroke causes it to stick to anything you're applying it with. By heating it up, I can do 2 or 3 strokes before it dries up and starts sticking to the applicator. I'm not comfortable heating up the die or the PCB so I prefer to heat the paste and spread.This is my opinion so do not take it personally.
I do not know why you have to use a hair dryer to ensure that the thermal paste is spread evenly.
Is like spreading a jam on a bread if you heat up the jam it will harden and the contact
will even be worse.
For me I usually just put a bit not a lot just few a drop either on the center or for large die than
few drop. Than I will use the HSF press down first to ensure that the thermal paste
is just right before screwing it down.
Thermal paste just provide a contact between the CPU/GPU Die and the HSF so by right
it must not be too thick. Thermal paste does get dried up after something, this is something
hard to avoid.
So get a good thermal paste like Noctua HT-N1, there's no need for very high end or
liquid metal which makes not much of difference.
I have tried before electronic thermal grease before brought from Sim Lim Tower in the paste.
Computer manufacturer thermal paste works better for PC parts than electronic thermal grease.
For me when temperature creeps up after sometime especially GPU.
I will use paper towel, wipe it thoroughly using isopropyl alcohol make sure that the both
the CPU and heatsink have no residue of previous thermal paste.
Use a hairdryer blow both the CPU and heatsink first, wait a while before applying
a drop of thermal paste. I will than press down the heatsink if the spread is uneven,
I will just apply a drop of thermal paste to that area.
This is how I apply thermal paste so far no issue temp for my PC is alright.
CPU die is easy to apply thermal paste but GPU really have to be careful especially
it's die size.
Just to clarify, you don't heat up the CPU or heatsink before applying TFX. You heat up the TFX away from the CPU/heatsink before applying it. What I did was to put the TFX into a small ziploc and leave it in a thermos cup with boiled water for about 30 minutes before using it.This is my opinion so do not take it personally.
will even be worse.
hard to avoid.
it's die size.
This is an online forum. You are free to share your opinion.I don't use RTX3000 series so I don't know what are the temps are like.
BTW such cards if under warranty, it is best not to dismantle it just to reapply thermal paste.
Unless no warranty or brought from Amazon etc. than possible.
Given what I see, can try Thermal grease but have to get the correct one that isn't electrical conductivity
else risk of shorting the card. PS I hope no one come at me for saying elmariachi is wrong,
let me emphasis the point is that thermal paste shouldn't dry up that fast.
High end graphic card will definitely be hot no matter what thermal paste you use.
Unless you want better temp than maybe try thermal grease which can be brought from
either Sim LIm Tower or RS.
I have remove that comment else more will come at me.
No one is going after you for anything. I know the pains involved for tearing apart a graphics card just to repaste. My experience with TFX is the same as what @Lastwishes has mentioned. It is also a pretty common scenario where most ampere cards at the start of production had shitty mounts and uneven paste spread having a significantly high hotspot delta out of the box. If you bother so much about warranty, then leave it. But don't expect dealers to RMA the card due to this they will simply return it back to you and say all working within tolerances. The only way is to do a repaste properly. But truth be told the main reason why most people even take apart the card is to replace the stock shitty thermal pads and while you're at it, might as well paste it with something good like TFX. Even high end cards have abnormal temps till people started remounting their cards with better pastes which yielded significant improvements.I don't use RTX3000 series so I don't know what are the temps are like.
As mentioned I am not here to argue with anyone, my point is very thermal paste should be
easier to apply if it is not than change.
High end graphic card like RTX3000 series are hot, out of factory usually the paste and thermal
pads are just normal type.
I be blunt if the card is hot, so long it doesn't artifact or causes instability like shutdown etc.
than should be OK. Is hard to maintain a low temperature for cards like RTX3080 or RTX3090 since
it's TDP are near 300 watts onwards.
Thermal paste have TDP limit, if it is for 300 watts TDP onwards than thermal grease
will be recommended. It's been very long since I use thermal grease so I can't say
which is good for 300 watt TDP onwards.
Highest end graphic card I have played is only up to RTX 2080, I rarely game so
I don't see a need for modern graphic card.
https://sg.rs-online.com/web/c/hvac...cs-heating-cooling-components/thermal-grease/
If anyone wants to try thermal grease, just make sure it is not electrical conductivity else
it will short the board.
I am not sure if there is a TDP limit for thermal compound or thermal pads. The manufacturer only mentioned the recommended operating temps.As mentioned I am not here to argue with anyone, my point is very thermal paste should be
