nomoreliaola
- Mar 4, 2008
ah crap today is the day i supposed to port out of giga to m1. but i recived sms that porting failed.
Read HWZ Forum Rules!
Check both account first name, last name the same. Lol my previous porting got issue cause they input them incorrectly.ah crap today is the day i supposed to port out of giga to m1. but i recived sms that porting failed.
Anyone can advice how to solve the sms not working problem. Happened a few times last few months, very disruptive.
All sorts of sms, banking otp, 2fa for apps.Which telco and which sender? So far I have no issue with Giga! It could be sender issue.
If this affects all sorts of SMS, OTP or 2FA, I feel the issue is with your phone or network connection.All sorts of sms, banking otp, 2fa for apps.
I even have to send myself a sms just to test if the function works before I need to use OTPs if I receive the same text in the same window, it means sms function working.
Today it magically worked again without any settings changed. 24 hours after I left a message for tech support via giga app.
I am using more than a year already. The $18 100GB 300mins plan really can't grumble for me liaoAny idea why lots of people porting out of GIGA?
Well, I dont have much complaints with giga for the amount I pay but ported out because of the lack of VoLTE support on my phone. Have been waiting for them to maybe expand the list of handsets they support but sadly I dont think there's much progress on that front. The data rollovers and freebies they dish out occasionally are nice but I dont really get to fully utilise them anyways.Any idea why lots of people porting out of GIGA?
No signal or got signal but no data? No signal means their base station down.today at Raffles city basement 1, no signal can't WhatsApp at all.
Will probably have some pro-rated charges from 1st Oct to the day the number porting is done to your new giga sim card.This is my first time doing a telco switch, all along have been using M1 prepaid then M1 sim-only. Read through some threads and I’ve decided to port in to giga on 1st Oct 0000 hrs. Anyone can advise if M1 will charge me for the few minutes of usage on 1st Oct? Sorry if is a dumb qn, really dk where else to ask
$18 for 100GB?I am using more than a year already. The $18 100GB 300mins plan really can't grumble for me liao
Ah makes sense, thanks!Will probably have some pro-rated charges from 1st Oct to the day the number porting is done to your new giga sim card.
