- Sep 16, 2018
EA8100 openwrt wifi speed test is too slow and unstable: 100-200mbps. When I use linksys firmware, speed test can reach 300mbps (Singtel 500mbps network).
Any solution for this?
I enabled fast roaming in openwrt, it should not affect speed test result, right?
I have enabled Software flow offloading and hardware flow offloading in openwrt.
If you suspect fast roaming then just test it again with the feature disabled. I have never tried that myself.
What is the client used for the testing? Are you using the SpeedTest app? DO NOT use browser which may affectt the test results. And make sure you test the wired results first.
You can scroll back one page to check my wireless test result of Linksys EA7500v2, it is quite decent with OpenWRT 22.03. I did not change much on the wireless side (change the country to SG and then set up the password). I am using an Acer laptop with built-in Intel AX201 wireless adapter, Singtel 1Gbps plan. This result at close range should match the performance of Linksys stock FW.
