I assume outdoor is similar NR SA coverage.
But indoor (commercial buildings), it might be different.
It's also the same. How can be different if they use the exact same towers?
Where did you get the idea that they use the same tower?
Indoor antennas are separated.It's also the same. How can be different if they use the exact same towers?
You can always have different channels in the same spectrum lot.StarHub and M1 formed the Antina JV to bid on the 5G spectrum auction in 2020. They won the auction and now both operate 5G together on the same spectrum. If they share spectrum, it is physically impossible to operate in the same space using different equipment, as TDD 5G (on the n78 band) using different signalling timings is a recipe for disaster. Because of that, given they both have islandwide networks, they must share the equipment.
Also you connect to StarHub's 5G towers while on M1.
https://www.cellmapper.net/map?MCC=525&MNC=05&type=NR
For example, maybe 50MHz each to deploy inside the buildings?
Many hard ons on the ceiling everywhere, it’s frightening.Indoor antennas are separated.
Don't you see at the ceiling of the commercial building there's those picocell antennas that either look like some guy has his hard on, or those square boxes with carrier logo?
Each operator roll out the in-building coverage separately normally, unless previous agreements were made and it's marked as "CAS" instead of the respective carriers.
This is why there will be in-building coverage where StarHub have 5G while M1 doesn't, and vice-versa.
They should have RF engineers that test all these. If they can't even get things done properly, I'm speechless.My concern there is that it would interfere with the outdoor reception because indoor and outdoor cells would have different configurations and timing offsets, especially if they are operated independently by both SH and M1
Later on suddenly it decide to "explode" on youMany hard ons on the ceiling everywhere, it’s frightening.![]()
I cannot even receive OTP when I am on 5G …. Only can when I switch back to 4GSo seems like M1 still long way to go for island wide coverage?
are you able to call or receive while on 5g?I cannot even receive OTP when I am on 5G …. Only can when I switch back to 4G![]()
i worse...cannot receive and make call...had to switch back 4g then only cancall can … but receive never monitor …. Data is not stable … at least for my case. And when I cannot receive the otp from bank when on 5g really turns me off.
For now I think SingTel 5G is the most stable … Frds who under SingTel all got no complains.i worse...cannot receive and make call...had to switch back 4g then only can
What phone?I just moved to M1 5G SA, SIM only plan. The 5G coverage really CMI, GOMO better. And that's very telling of how bad it is, because GOMO has a lot of dead spots.
GOMO is NSA leh.I just moved to M1 5G SA, SIM only plan. The 5G coverage really CMI, GOMO better. And that's very telling of how bad it is, because GOMO has a lot of dead spots.
