frizee
- May 5, 2006
Recommend to put TPG for APN.
Sigh, cuz with or without APN: TPG, making/receiving calls are still intermittent…
Did u reset your network settings and set up TPG APN again? Previous settings might be screwing up your device.Sigh, cuz with or without APN: TPG, making/receiving calls are still intermittent…![]()
I did a full restore of iOS bro, haha so it’s considered a fresh new settingDid u reset your network settings and set up TPG APN again? Previous settings might be screwing up your device.
I don’t know what’s going on… Since morning I can’t make/receive calls (intermittently)
Hmm iPhone users here? I’d like to ask…
Is there a need to add “TPG” to APN for Mobile Data and LTE SETUP?
Sigh, thought this SIMBA was good, but, lol dunno why met with such technical issues...![]()
What APN are you using?I don’t know what’s going on… Since morning I can’t make/receive calls (intermittently)
I am using Redmi 9s, which is listed as one of the approved handset for SIMBA. And yet I have difficulty in using the roaming call in JB, whereas data roaming is alright.What APN are you using?
My TPG line on iPhone 7 with APN set to tpg (on mobile data section only) can call without using voice app and data roam in Malaysia. OR are you in some basement level where TPG coverage is cmi.
So you are in JB and wants to make a roaming call from JB to Spore or JB to JB right? And you can't dial out even when using +65xxxx-xxxx right? Not sure what's wrong then. Maybe Operator not supported??I am using Redmi 9s, which is listed as one of the approved handset for SIMBA. And yet I have difficulty in using the roaming call in JB, whereas data roaming is alright.
I have approached their support team. But no solution, and I am advice to use their voice app, which I refuse.
The roaming call was made from JB to Singapore. Just for trying out. But failed. Once i step on Singapore Custom checkpoint, the calling resume as normal.So you are in JB and wants to make a roaming call from JB to Spore or JB to JB right? And you can't dial out even when using +65xxxx-xxxx right? Not sure what's wrong then. Maybe Operator not supported??
But anyway why use direct dialing which will incur charges when I suppose using the Voice App will not incur any extra charges except consuming some data.
See below:
Voice Calls
To make and receive calls via VoLTE, here are the following requirements:
Otherwise, download SIMBA Voice App. You can enjoy FREE unlimited outgoing calls to Singapore Mobile numbers, FREE incoming calls and FREE incoming SMS with the SIMBA voice app in all 124 destinations.
Please add +65 if you are making calls to Singapore while roaming.
If you wish to find out how your plans will be deducted, click here.
Full restore or full reset?I did a full restore of iOS bro, haha so it’s considered a fresh new setting
So bro do you have TPG under these 2?
Okay so all 3 section I’ll add TPG and see how it goes first.Full restore or full reset?
Restore will place every setting back to where it was last backed up, so any cockup will still be placed back.
And yes, together with hotspot.
I'm using SIMBA on iPhone for v long time now. Only need to set apn for mobile data and hotspot, no need to care about lte. Volte and roaming both work well.Okay so all 3 section I’ll add TPG and see how it goes first.
Restore - meaning i installed a fresh new ipsw, like when you first boot up and set up the iPhone as new bro haha, not “Restore from backup “.
I’ll monitor and see if the intermittent issue persists, thanks anyway!
Roaming to which countries work well for youI'm using SIMBA on iPhone for v long time now. Only need to set apn for mobile data and hotspot, no need to care about lte. Volte and roaming both work well.
hi there.. I just inserted the new Simba sim into my hp and activated successfully from the website
My number is ported from Changi Mobile. So right now the new sim shows "No service" even when i choosen TPG SG as my network selection.
So does it mean this new simba sim can only be used when the my number is ported from changi mobile? Is it done tonite midnite?
Need Simba users' advice.. Thanks
Uhmm I got ported over same day midnight…hi there.. I just inserted the new Simba sim into my hp and activated successfully from the website
Been on LTE the entire day, feels okay.. But, yesterday intermittently cannot make/receive calls but today seems stable (for now) lol…Currently on a $17.90 Gomo plan, should I be a cheapskate and switch to $10 simba plan? I don't go overseas.
I'm newbie too, last week!Ok.. found the answer: Need to wait 2 days
https://jilaxzone.com/2022/09/29/he...n-your-number-to-simba-formerly-known-as-tpg/
Information for newbies![]()
Please do so. SIMBA network is quite good now even the speed test shows slower speed. Nothing to worry about that.Currently on a $17.90 Gomo plan, should I be a cheapskate and switch to $10 simba plan? I don't go overseas.
