INTEL CPUs *OC Benchmark & Discussion*
matique
Well for eg claimed here there is lower power draw but everything i have seen from leaks and official announcement is higher power draw. Stuff like this just makes me wonder
I say similar ah not lower ;). And yes I can't share SS + source since it can always be traced back, and this is a public forum after all. No need to take me so seriously anyway and keep digging at it. Up to you to believe or not, and ofcourse you can always wait accordingly.
Aggresive pricing, better performance, runs cooler, similar power draw, much better ddr5 scaling. Keeps on winning. Well except for board life but I can live with that.
celsus
Ok sorry i misread ur post
AZE
Looks good.:o
watzup_ken
Looks good.:o
It looks too good to be true (specifically the power draw), and knowing this came from Intel, I think you should just wait for official testing results since the results are heavily biased. However, given the extra e-cores, it is expected that Raptor Lake will fare better than the Alder Lake part that it is replacing.
Phen8210
In their measurements, 13900K used 5600 MHz ram, compared to 12900K using 4800MHz ram.
But I wouldn't say it's impossible because the Ryzen 7950x 65w eco mode (actually 88w) did better than 12900k in multicore. So it's possible, especially given that intel has spammed numerous e-cores in the 13900K.
elmariachi
That is because 13th Gen and Z790 boards are now 5600Mhz base effective JEDEC frequency. While 12th Gen and Z690 boards was 4800Mhz base effective JEDEC frequency.
Phen8210
https://www.digitaltrends.com/computing/intel-alder-lake-bios-source-code-leak-is-real/
Hardware security firm Hardened Vault told Bleeping Computer:
The attacker/bug hunter can hugely benefit from the leaks even if leaked [manufacturer] implementation is only partially used in the production. The Insyde’s solution can help the security researchers, bug hunters, (and the attackers) find the vulnerability and understand the result of reverse engineering easily, which adds up to the long-term high risk to the users.
LiLAsN
One of the youtubers have set a schedule and it revealed that it should be lifting at 9pm tonight. The same time the CPUs are released.
htancl
Normally for Intel new gen CPUs, how long Singapore will get the stock after the official launch date?
