Intel ARC series GPU (Over 40% perf/$ vs Nvidia)
Phen8210
A750 Performance vs RTX 3060
A750 Perf/$ vs. RTX 3060
Arrives on 12 October 2022
chiu2000
As Jayztwocents says, you can achieve high perf/$ by pricing it low and even sell at a loss at the most extreme case
I will believe it only when the numbers are out
ragnarok95
Senior Moderator
Senior Moderator
Waiting for member to give up their 3080/3090/6900 and buy a A770.
matique
I think it'll make for an excellent NAS/Plex server for some overkill encoding decoding
Koenig168
Arc needs Intel 10th gen or AMD 3000 or higher. This rules out a big chunk of the budget market which Arc is targeting.
Arc will still work with older CPUs but there will be a performance hit.
Phen8210
performance is so inconsistent :s22: .. give them a few months and lets see if any improvement..
potential is there
