 Watch Ultra
ryan_khoo
I find the action button is pretty useful to start workout (which I set it as), but I believe in future more 3rd party ones such as Strava will be able to utilise the action button. The AWU is built way differently and after using AW for 7 years, AWU felt like a smart watch in G-Shock style.
Bro, izit possible to configure the Action button to stop a run ?
Thanks
Habrosus
Thanks
That Action button has very limited functions right now, hope they add some more useful ones through some software upgrades.
The present stop method makes no sense to me either.
numzkull
Yup but the wound’s still ‘wet’ for now, doc gave antibiotic cream for application, so I covered with a gauze.
Wah many thanks bro, really appreciate that.
Check with doctor if it’s ok to use hydrocolloid plaster. It’s supposed to help heal wounds faster and protect against infection vs traditional gauze.
Snoweagle
Wow....can buy this over in pharmacies or only via prescription?
caesium2108
When did you place your order ?
or do you mean you walk in and got stock ?
thanks
Just placed order 5 mins ago. i think still got 1 stock for trail loop. everyday at random timing i will just log in to check on all models at different sizes see got pick up option or not.
ryan_khoo
Yes the present stop method makes no sense. Could it be that they are designed by those who are not into running, so they don’t really know the problem ?
