Called but said number not availableHmm, at the very least, can you use your working sim to call this TPG sim?
Or, does it even show the telco logo?
Shows SIMBA logo, 4-5 bars and LTE
That's why I find it weird
Hmmm... Under Settings - Mobile Data Options - Voice & DataCalled but said number not available
Your spare iphone is which model? some older series not supported by TPG/Simba direct dialingI just got my sim card 2 days ago, and popped into my spare iPhone. When setting up iPhone, iPhone can't verify my number via SMS or call because my number "is not valid".
Thing is, I can't even get past the "introduction phase" because iOS can't verify my phone number when creating a new Apple ID, so I can't even go to the "Welcome to iPhone" and then home screenHmmm... Under Settings - Mobile Data Options - Voice & Data
1) Ensure LTE is checked
2) Turn on VoLTE (ignore and acknowledge any prompts that come up)
Let me know if it works...
SE 2022. Should be supported since SE 2020 was supportedYour spare iphone is which model? some older series not supported by TPG/Simba direct dialing
Lol no no, skip Apple-ID sign in broThing is, I can't even get past the "introduction phase" because iOS can't verify my phone number when creating a new Apple ID, so I can't even go to the "Welcome to iPhone" and then home screen
Ya hor I forgot it is possible to sign in without Apple IDLol no no, skip Apple-ID sign in bro
Else, pop it into an iPhone which is done setting up, then follow my steps and see if it'll work?![]()
So bad?WAH THIS SIMBA TPG REALLY DAMN JIALAT....
Each time I insert the sim into another phone, I get these random "DOWNTIMES" when I CANNOT make/receive calls and SMS...
Really want to port out already sia..![]()
Then why not get two line or two sim?Hmm to cut it short, between work phone and personal...
That aside, I dont experience these 'random downtimes' with other telcos though...![]()
LOL I have more than 1 SIM of course, but the point isn't getting more SIMs, it's about the random downtimes im getting from TPG SIMBA bro... LOLThen why not get two line or two sim?
Lol so now ok? Tried the steps liao?Ya hor I forgot it is possible to sign in without Apple ID
should work for most samsung phone .. works on my s22 dont see why notDoes Simba support S21FE natively? Thinking of trying out Simba. It is not exactly part of the "S21 family" quoted in their supported devices list. Thanks!
No problem with S22U too...Does Simba support S21FE natively? Thinking of trying out Simba. It is not exactly part of the "S21 family" quoted in their supported devices list. Thanks!
my friend oppo phone didnt get any data even showing 4g .. he have to wait few hours and reboot the phone few times to get data for some reason... APN is all correct ..No problem with S22U too...![]()
Lol, like that also can, mine is opposite lah...my friend oppo phone didnt get any data even showing 4g .. he have to wait few hours and reboot the phone few times to get data for some reason... APN is all correct ..
Still cannotLOL I have more than 1 SIM of course, but the point isn't getting more SIMs, it's about the random downtimes im getting from TPG SIMBA bro... LOL
Legit their service standard is good? Hmm…Have been using Simba for past 3 months. Have to say like it more and more. 100GB, hot spot till i siok. Go MY got 1GB free roaming just nice for 2-3 days trip. No problem for usage in SG anywhere [at least for me]. They are the one started with $10 100GB and now we see many copycats. I will support them if the service standard maintain and/or continue to improve.
Hmm then I can’t think of any other methods alreadyStill cannot
Set up without Apple ID, select VOLTE, then tried to set up Apple ID
Number still invalid![]()
Funny thing is SIMBA number can receive SMS/calls from my working SIM. And I can use the LTE data.Legit their service standard is good? Hmm…
They even twice failed to respond after 2 days, had to send a chaser lehhh…
Maybe go back to the stall and enquire? Could it be the staff didn’t activate it at their end?
Hope they give you a satisfactory explanation.Funny thing is SIMBA number can receive SMS/calls from my working SIM. And I can use the LTE data.
So frankly I have no idea what is even going on. Looks like we facing roughly the same issues.
Already emailed SIMBA to help me on this
