dmleaf
Thanks. Ya, am aware of it can be used in msia only.
using the data passport from m1, but it increases to 12/30days +5 activation , might as well get from tpg.
I wonder if I can buy one month the 10/mth plan to test in Malaysia then only change to 30/90days my130 plan?
gapboy
dont think you can change $10 plan to my130 as it is online exclusive as i mentioned.. you can ask and let us know
Tomtoh
It's confirmed that SIMBA allow upgrade of plan now. (excl. upgrades to SIMBA MY130).
Some plans also cannot upgrade to others. That one need to enquire further.
lohsenglte
I think 805x are very new and not recycled.
Want to be safe, get 804x and above, numbers are much less likely to be recycled.
Too new and that's why many services haven't accept the number range yet.
Don't be surprised if OTPs don't come in because of that. It'll be painful.
Ye_Rongtian
lohsenglte
New number also can get spam calls. My number is 8057 xxxx.
At this point, any 8* and 9* numbers will get scam calls, be it new or old.
They just jam the telephone network since it cost so little with bulk purchases.
One person fall for the trap with multi-grand cheated, easily whole month's bill covered.
otacon
Can i confirm if Redmi 10A works with simba? I am getting a new phone for my grandfather n couple with simba senior plan. Needs to know if i can buy Redmi 10A or not
needhelpbadlynow
If xiaomi phone by default no volte and musr dial code to unlock function, moi do not recommend. Because moi de old xiaomi did tat using code and the phone gets hot and battery drain fast.
So unless in normal android settings can turn on volte, otherwise really not recommend..
If you looking buy phone for old people use moi suggest you buy Samsung Korea refurbished export set just around 150. It is 1 or 2 years old phone model but the function and OS very updated because its Samsung.
needhelpbadlynow
Anyone know if simba can top up cents? Like 10 cent 20 cent? Because moi got value 4.90 and cannot use to renewal minimal is top 5 dola will become 9.90
needhelpbadlynow
thats the phone issue .. but simba works with xiaomi thats the question
It works but it's hot and drain battery tats wai by default the xiaomi phone not all phone have the feature in plain OS level must dial code to turn on.
Moi gave up because it drain battery and dial code to turn off the feature. Just use simba apps better at least battery not die fast
lohsenglte
Weird. I tested on a few XM/Poco devices no such issue.
No. Min $5.
needhelpbadlynow
No. Min $5.
Moi bluff chiu for what sia. 🤣 If the settings ish meant to be use and ok with performance wai them not incorporate into the UI? 🤔
Die die must make users go dial phone codes go into deeper level to enable it.
Phones with volte capability like huawei and Samsung etc all ish no need dial code to enable because they know it ish stable to use and its supposed to be automatically.
Moi ish have mi sam hua all 3 brands actively using de so moi know the difference. Fact ish once xiaomi phone turn on the settings using code it will consume more power. The standby time will drop.
Tis one ish common sense also because sam n hw phone their volte by default ish turn on so when user use the phone ish like normal won't notice battery power consumption because the phone was originally in volte state.
Moi tink every one can agree rite so long turn on more services it will jiak more power cpu or memory . Tis ish basic OS way of working
