[Software Update] iOS 16.2 Beta
kmkimlo
Hopefully come out soon.. i wanna try stage center for the ipad
thenakedshades
Is anyone POSB/DBS app for FaceID still broken? I’m on 16.1 DB4 with new POSB app update today
Jirachi
That's what you get from using beta IOS, no? :ROFLMAO:
No. It was a problem with 16.0.X before I went to beta to attempt to fix this issue.
I normally jump to beta in an attempt to fix problems. But I understand that the Face ID issue is now fixed on the public release version.
Fellowes
DBS iBanking App Face ID is still not working on iOS 16.1 RC
Good luck, DBS!
Other bank apps with FaceID all okay but DBS faceID fail in iOS 16.1 RC. Lousy sia their software development.
Fellowes
no problem logging in DBS with face ID for me (16.0.3)
Guess the iOS 16.1 break some api in the DBS bank app then this FaceID fail and prompt: “service isn’t available right now”. For now, use pin to login was okay though until they fix it.
