As this phone is using a tensor G2 built by samsung's 4nm process (same as the 8 gen 1 not 8 gen 1+).
I will be a bit concerned about thermal throttling.
They kept the same cpu 'essentially' and bumped up the clocks slightly and changed the gpu to a more powerful one (same as dimensity 9000).
So, essentially, some heat reduced because they went to samsung's 4nm from their 5nm process.
But, heat increased as the clocks are higher and the gpu is more powerful.
For those interested, the gpu component should be slightly more powerful than an apple A14 chip.
