Google Pixel 7 series
What upgrade would you most like to see on the Pixel 7 series?
  • Total voters
    140
joesph
How's the wifi stability for you guys? Mine quite disappointing. In my room the router in living room can't get connection at all. I have to move out to living room or connect to my other wifi network. And if I lie on the bed and use phone even worse. All my old phones not like that, even my old S7 edge
don't know yet but 6a Wi-Fi is very good range
Read HWZ Forum Rules!
FreddieFreako
Ok I factory resetted, but restored data via Google One. Singpass sets up fast and seemlessly now.
Good to know and thanks for sharing.
I dread having to re-load the data and re-login to all the apps all over again. :(
Have to do it if there is no other workaround. :(
liuhz_editorial
Nice shots. After seeing more people try their 7 Pro I'm also noticing that the telephoto's colourisation seems a little off when compared to the main and ultra-wide.
year2013
SINGPASS app issue, please let me know if someone able to resolve, I tried everything butcsame error
liuhz_editorial
How's the wifi stability for you guys? Mine quite disappointing. In my room the router in living room can't get connection at all. I have to move out to living room or connect to my other wifi network. And if I lie on the bed and use phone even worse. All my old phones not like that, even my old S7 edge :(
Generally okay with and without LOS, even at a distance (different room). Tried streaming shows, socmed, and doing light work (email). Speedtest claims there's high jitter, but no packet loss.
woonyoung91
Just proceeded to reset my phone, hopefully singpass works and its worth installing and setting up all apps from scratch again. :sick:
godspeed2000
I missed all the preorder deals and want to buy now... Where's the best place to buy now? Challenger/Courts for 50 off and free gift? Any other good lobang?
crow_nest
So far only workaround is factory reset. Apparently the day 1 security update botched singpass if you try setting it up AFTER the update.
Just do a google one backup in settings, then factory reset. Once resetted just restore via google one backup. The only apps that need re-setup are the banking/transport/food delivery apps and of course all your biometrics.
limmk
What i do on my p6p prior to copy over to p7p
back up phone by google one
back up your WA/Signal/Line etc.
start copy over
transfer account google authenticator
restore your WA/Signal/Line etc
add credit cards / biometrics
also note that you need to enable developer option again
turn off mobile always active
change animation to .5x
顺顺 bo tai ji
