Google Pixel 7 series
What upgrade would you most like to see on the Pixel 7 series?
  • Total voters
    140
ranmaru1987
So far only workaround is factory reset. Apparently the day 1 security update botched singpass if you try setting it up AFTER the update.
Just do a google one backup in settings, then factory reset. Once resetted just restore via google one backup. The only apps that need re-setup are the banking/transport/food delivery apps and of course all your biometrics.
if i do day 1 update then factory reset then install Singpass will i encounter any issues?
ruvanist
If i do fresh install of Singpass (instead of restoring from old phone backup), will there be any issue?
ruvanist
Anybody got recommendations for magsafe grips or phone loops? Intending to order a magsafe compatible case.
wongminmin
:s22:
beano
Only 1 app f it up so bad, really poorly developed
Read HWZ Forum Rules!
Vulpix
Moderator
Moderator
I did a factory reset, still doesn't work. I suspect this is probably GovTech issue tbh.
edit: Ok I rebooted just to try luck and it works now. GovTech probably did some shortcut and messed up something.
algerr
u still have to update software when the next patch comes..
so might as well pain one time.. update phone, factory reset.
crow_nest
Anyone know if you use the $250 voucher to buy another P7 from google store, will they give you the $250 voucher from the 2nd purchase as well?
wongminmin
i think the google voucher will issue after 2 weeks...and the $250 event ended by 16th.
looool
Giga dont support VoLTE on Pixel 7 series zzz. Not sure if they ever will.
VoLTE / VoWiFi works on my iphone 13 pro on giga, and i even get 5G signals on my iphone 13 pro (for free since i did not pay for the 5G add on). not sure if i can still get 5G signals on my P7P
