- Sep 16, 2018
I have an ONR, and Singtel Mesh Router and poor coverage in my MBR. Backstory is here. https://forums.hardwarezone.com.sg/threads/singtel-onr-ap-issues.5778791/post-140653993
So I bought a Singtel Mesh Extender (V2) off carousell, and paired it with my Singtel Mesh router via WPS, as per the manual. After a brief wait, the SSID of the Mesh Extender changed to the SSID of my Singtel Mesh Router and it appears to have worked. This is because I could see the "Mesh" LED light up on the Singtel Mesh Router, and in the Network Topology section of the Singtel Mesh Router's admin portal, I can see that the Extender is connected to the Mesh Router.
So I tried to connect to see if wired backhaul could work with the Mesh Extender. So I plugged in power and an old Cat5E cable to the Extender to the MBR lan port, and switched it on. But it feels like I have 2 APs with the same SSID rather than a Mesh network. This is because with the Mesh Extender in the MBR, the Mesh LED is no longer lighted up on the Mesh Router, and the Mesh Extender disappeared from the Network Topology section of the Singtel Mesh Router's admin portal.
In the Singtel Mesh Extender's admin portal, in the Network Status section, I can see a graphic that the Extender is connected to Mesh Router as below.
But in the log section, there is a line that says "Backhaul Ethernet being used for uplink mode." See screenshot below.
So do I have Mesh? or 2 APs with the same SSID?
Thanks for the updates.
I tend to think the Mesh LED on the Singtel Mesh Router is the right now.
Your results seem to indicate that wireless backhaul works but not Ethernet backhaul.
Hopefully more people will report their experiment with the Ethernet backhaul. Yours is the first case and it seems to say Ethernet backhaul does not really work in the first case.
1) Singtel ONT or ONR -- Singtel Mesh Router --wired -- Singtel Mesh Extender
2) Singtel ONR -- Singtel Mesh Extender (main node)
Singtel ONR -- Singtel Mesh Extender (mesh node)
