Arandalo
- Feb 22, 2014
Only non Jumbo plans can.Zero 1 jumbo still cannot receive OTP overseas right?
Yes for all telcos.Btw for porting number happen on weekday only?
Arh okYes for all telcos.
I collected mine on Sat around 9:30 am and porting started later on the same day around 11 pm. Probably you collected later in the day yesterday that’s why haven’t port yet. Likely tonight will be ported.Btw for porting number happen on weekday only?
Fast port over cannot tahan my m1 lineMine happened on Saturday around 11 pm. Probably you collected later in the day yesterday that’s why haven’t port yet. Likely tonight will be ported.
if your old line still active means not port over .. anyway yest was a sunday non working dayBtw they will send sms right when the number is going port over?
Mine still at m1 line
Porting doesn't work instantaneous like this. When original line loses signal and/or reception, there is still a few hours to go before its number is transferred to the target line. So typical downtime is around 11pm to the following 2am.You will know you have ported when you suddenly lose signal / reception. Then just put in the new SIM card![]()
Daily & it’s almost real time.Dumb question the app show data usage is daily one or monthly?
It won’t reset until your next billing cycle. If you used finish your bundle data then your usage counter will just continue to add on. For example if you’re on the starter plan and used up 6 GB, your data usage will show 6.01 GB and higher as you continue to use.Ok thank no wonder I keep see everyday usage like diff lol.
That mean the unlimited data = if 1 day finish the whole data will reset?
Not sure but they also comment my review shall emaio them and see what is the surprise giftBtw I saw Zero1 google reviews they started responding 2 weeks ago to the positive reviews saying “Hi XXXX, we’re so happy to hear from you! Thank you for your valuable feedback. We have a surprise gift for you to enjoy, please email us at marketing@zero1.sg to redeem.”
Wondering what is the surprise gift. Anyone can share if you know?
