[Software Update] iOS 16.1.2
Mclairs83
searching for app getting slower and slower.
sometimes type the exact word google will take 3 sec for the app to pop up.
我要买GTR
Hope 16.1 is out soon :confused:
I'm still getting black screen of death. Some people say is AOD issue but I don't even use AOD since day 1 lol..
szeli
maybe u shud turn it on. use e focus mode to change e background to black if it’s too bright for u
szeli
slower n slower? in spotlight? I type “go” I see my Google apps immediately
anthonygreenisreal
I find the iPhone 14 pro the battery life seems to have stabilized. It was quite cui over last 2 weeks but now seems pretty okie. Dunno is OS update or what.
arcturuz
Never experience this before. Perhaps you need to bring your phone to Apple to check
manofsorrows
do yall reinstall every new updates .. ie use computer to update or just use delta updates (ota update via phone) ?
NTTDoCoMo
xD not a tech expert. And I was trying to recollect all the recent changes I've made to the phone, so was process of elimination lor.
but now with nextDNS turned off, trying to find nother DNS profile to block ads system-wide. maybe nextDNS needs to update properly for iOS 16.
You can login to nextdns and add the blocked entries to the allowlist.
Previously i had the same issue where i cannot load app store too, i checked nextdns "logs" and add the entry to the allowlist.
After adding to the allowlist, you need to open nextdns and toggle the off/on switch for the allowlist to take effect immediately.
Computeron
any1 facing this?
when i wan to paste text... the popout of pasting will appear... n disappear n appear again
