Google Pixel 7 series
What upgrade would you most like to see on the Pixel 7 series?
  • Total voters
    140
Paladin1st
Has anyone tried the eSIM feature? Does it work at the same time with a regular SIM? Understand Android 13 also supports multiple profiles on eSIM. Would be great if this works at the same time. Imagine the convenience for travelling i.e. just purchase online, scan the QR code and instant access to local telco service :)
beano
Haven’t tried both together, but esim works like a charm, can’t see why it doesn’t work together.
Advancer
Film is thinner of course it’s work better with scanner. what make you think isn’t?
am using hydrogel throughout my curve screen phones. None issue with fp scanner.
Yah not sure if it's the same effect for optical sensor like Samsung ultrasonic sensor.
Thanks, will consider the ringke one.
Paladin1st
Thanks! Can you confirm that the eSIM and SIM work at the same time? i.e. as in dual SIM? As mentioned, it would be better if the multiple eSIM works at the same time. Understand from some on the internet that only one eSIM works at one time although Google has said that they are working on enabling this feature
reiji01
Just pasted Max tempered glass sp at Xgear Waterway Point. Thought it was WSD but different brand. Still using loca for bonding and fingerprint scan still works flawlessly. Much faster than my s20 FE
FreddieFreako
How much did you pay? 7 Pro?
Raheem1980
Got my p7pro on 14 Oct. Used it naked for a few hours before going to paste a 18 bucks screen protector at causeway point. It's hydrogel type. No brand but didn't affect fingerprint sensor at all.
Cannot find any p7pro cases at causeway point so bought the Spigen liquid air on Amazon for 19 bucks. Delivered today. So far so good.
Vulpix
Moderator
Moderator
Wtf 18 bucks for hydrogel sounds like a scam siah.
TopGun
Can the Pixel 7 uses a Qualcomm QC3.0 charger and charge at 18W? Or it will only work with a charger on PD or QC4.0?
