Google Pixel 7 series
What upgrade would you most like to see on the Pixel 7 series?
  • Total voters
    140
royfrosty
Just to double check are you checking through the :
About Phone > Android Version > Google Play system update
The above is the latest I just got it too, it's a small patch, upon updated the following was the latest
Doesn't work. It ask to download but during download it says currently unavailable.
Yongkit
Noted, perhaps will be in sync on next month update all together.
another alternative is to shut down phone instead restart. sometime will work sometime not I also confuse sometime
Chrisng_21
I only saw hazel, but I wanna see how lemongrass look like, I saw comments previously said picture not the same as the real colour.
lyk13
P5 no need to unlock anything.
You mean with screen lit up?
Won't get double charged one. If tap again the machine will just display ok
It is a double-entry in my GPay. That's the worry. And with GPay, they charge for all the stops you did that day so you can't really see individual trips.
They also show your entire trip for that day in the transaction for transport.
ybeex92
i have applied the Ringke SP on my Pixel 7 Pro and there is no camera cutout. Its just one single piece.
Only thing irritating for me is the center divider line which is used for easy application. Hopefully it goes away due to screen heat in a couple of days.
Yes exactly same concerns! the divider line is distracting for someone who has OCD like me. the lack of camera cut out seems to be a little bit lazy seeing that the SP came with so many bells and whistles to help in application.
Loser
I actually prefer no cut out because that can collect dust and it's even more irritating in the long run.
shager
Anyone knows if Taiwan Pixel 7 has call recording? Or which country is this feature enabled? Thank you
